Pekny vecer, do dnesneho dna mi vsetko slapalo tak ako ma, ale uz par hodin sledujem zvysene latency o 8 nasobok. Nezapajala som nic do routru noveho a nedotkla som sa toho nijako.
Microsoft Windows [Version 10.0.19042.906]
(c) Microsoft Corporation. All rights reserved.
C:\Users\45918>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Fuldkommenhed
DNS Suffix Search List. . . . . . : home
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : home
Description . . . . . . . . . . . : Realtek PCIe 2.5GbE Family Controller
Physical Address. . . . . . . . . : 2C-F0-5D-94-69-20
Link-local IPv6 Address . . . . . : fe80::55fa:5d9f:de10:d425%17(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.0.10(Preferred)
Lease Obtained. . . . . . . . . . : 07 April 2021 20:26:46
Lease Expires . . . . . . . . . . : 08 April 2021 20:41:27
Default Gateway . . . . . . . . . : 192.168.0.1
DHCP Server . . . . . . . . . . . : 192.168.0.1
DHCPv6 IAID . . . . . . . . . . . : 103608413
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-27-B2-63-D2-2C-F0-5D-94-69-20
DNS Servers . . . . . . . . . . . : 193.162.153.164
194.239.134.83
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Intel(R) Wi-Fi 6 AX200 160MHz
Physical Address. . . . . . . . . : E0-D4-E8-76-79-42
Wireless LAN adapter Connexion au réseau local* 1:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : E0-D4-E8-76-79-43
Wireless LAN adapter Connexion au réseau local* 2:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter #2
Physical Address. . . . . . . . . : E2-D4-E8-76-79-42
Ethernet adapter Ethernet 2:
Description . . . . . . . . . . . : Kaspersky Security Data Escort Adapter
Physical Address. . . . . . . . . : 00-FF-D7-54-01-98
C:\Users\45918>
C:\Users\45918>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.1:
Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
C:\Users\45918>pi
Co je zvlastne je to, ze ping na branu nejde, ale seznam.cz ano
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\45918>ping seznam.cz
Pinging seznam.cz [77.75.74.172] with 32 bytes of data:
Reply from 77.75.74.172: bytes=32 time=32ms TTL=54
Reply from 77.75.74.172: bytes=32 time=33ms TTL=54
Reply from 77.75.74.172: bytes=32 time=39ms TTL=54
Ping statistics for 77.75.74.172:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 32ms, Maximum = 39ms, Average = 34ms
Request timed out.
Request timed out.
Request timed out.
Request timed out.
C:\Users\45918>
Pingplotter: https://snipboard.io/BqR0vU.jpg
Latency
Re: Latency
1. ping na 192.168.1.1 ti jít nemůže. Sice sis přečetla článek, ale nějak ti uniklo, že tvoje brána (router) je 192.168.0.1.
2. Přečti si pravidla. Nebudu klikat na bůhvíjaký odkaz, pod kterým může být cokoli (ani ty bys neměla). Obrázky se vkládají sem jako příloha.
DonMilanez
- Level 2.5
Re: Latency
C:\Users\45918>ping 192.168.0.1
Pinging 192.168.0.1 with 32 bytes of data:
Reply from 192.168.0.1: bytes=32 time<1ms TTL=64
Ping statistics for 192.168.0.1:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
C:\Users\45918>
C:\Users\45918>
Re: Latency
Ztráty paketů začínají na 6. hopu 62.115.121.16. Od té doby je znatelně delší ping > 100ms.
Takže screen pošli providerovi, ať se ti k tomu vyjádří.
DonMilanez
- Level 2.5
Re: Latency
Uz sa tak stalo, ake je mozne riesenie takehoto problemu vo vseobecnosti? Router sa pokazil po dvoch mesiacoch alebo kde moze byt pravdepodobne problem?
Re: Latency
Problem je v siti poskytovatele, router je v poradku.
DonMilanez
- Level 2.5
Re: Latency
Dakujem, tak uz som im pekne poslala screenshot nech to poriesia. Prajem Vam pekny vecer a dakujem za pomoc.
