Potřebuju poradit, chytam wifinu za oknem, a chci ji dostat do notebooka, ale sedět ve vokně je blbost. Notebook je:
Kód: Vybrat vše
HP Compaq NC4000 laptop computer, well built with charger and mains lead and carry case.
Very fast Pentium M 1.4GHz processor = 2.8GHz speed, 512Mb of RAM. 40GB hard disk, external DVD player & CD read/writer included.
Clear 12.1 inch display, Integrated 56k modem ,10/100 Network card & 802.11b Wireless LAN Wifi.
2 x USB, Ethernet, Modem, Bluetooth, IR port, PCMCIA slot, SD card slot, S-Video out. Monitor out, audio in & out. Dual pointing devices (Pointstick/Touchpad).
Slim light weight design. 27.94cm (W) x 23.37cm (D) x 2.79cm (H). 1.59Kg in weight (light). Very quick machine. From full charge the battery gives about ~1.5 hours of use but can do more or less depending upon the power management setting.potřebuju poradit, jak nejlevněji a nejjednodušeji to zařídit, aby ten signal chytal i v pokoji, třeba antenu a kabel přímo do notebooka, nebo tak...
Díky
